Creating a shell from solids, NURBS surfaces, and planar objects
Tool
Tool set
Shortcut
Shell Solid
3D Modeling
Shift+G
The Shell Solid tool creates a hollow shell from a solid object or gives thickness to NURBS surfaces and planar objects. Most injection-molded plastic parts have a shell.
Shell from a solid object
Shell from a NURBS surface
Shell from a planar object
Concept: NURBS curves and surfaces
Direct modeling with the Offset Edge tool
